Emergency shut off switch ?
Frank Acampora
You can get non Mercury switches either way. The ones with four spade terminals on the back use one set to make a circuit and the other set to break the circuit. The specific one you showed, being a Mercury switch is most likely a make switch. That is, when the lanyard pulls the switch to off position, the circuit is completed and the electronic ignition is shorted to ground, stopping the engine.
K-2
Should work for me then. My shut off solenoids need 12V to kill the engines . I'd like something fairly waterproof.
Thanks!
