mitch_houser
Thread starter- Joined
- Aug 26, 2011
- 25
Here are the pics of my problem where the linkage is I need to remove this shaft.I bought a new coupling for 70.00 the splins where worn off it.It is connected to a rod that slids up, it has a flat on it you can feel it drop in place when you rotate it.But when you get the L/U in place it won't hold when you shift it will move into gear then want hold enough for it to move the shift shaft in L/U you can see the rod from the top spin freely when you shift with the lever control.With L/U out you can feel the lower rod with the new copling move also like its suppose too but when you mate them up and it goes up on this very easily no binding nowhere it just want hold.I need to know how do I get that shaft out without removeing the engine??
