MarbleheadJim
Thread starter- Joined
- Aug 27, 2020
- 2
So here's an interesting one. I have a 2000 SeaRay 21.5 ft with a MerCruiser 5.0 and Bravo 3 outdrive. I'm told it's a Thunderbird 5. I am getting a "beeping" alarm when I get my RPM's above approximately 3200 RPM. I also get the alarm when I "throttle up" quickly from idle to full throttle after about 5-10 seconds. When I back off from either condition, the alarm goes away. Boat runs real smooth, like nothing is wrong. It also does not go into "safety" mode and cut the throttle back - I can go as fast as I want. If I cruise around at 2800-3000 RPM no alarms. Runs fine. You'd swear nothing is wrong. Here is what has been done so far:
* Temp sensor changed (old and new show 170F on the gauge; no temp problem; impeller changed last year)
* Oil pressure sensor changed (old and new show 40 lbs on the gauge; no oil pressure problem; oil level good)
* Disconnected outdrive reservoir (no change; reservoir is full)
* Complete tune-up (plugs, cap, rotor, ignition module under rotor; spark wires are almost new)
* Fuel/water filter
* Carburetor was rebuilt 4 years ago (2-barrel throttle body injector, new needle valves (genuine - I was lucky to find!)
Once we did the complete tune-up, I noticed it wasn't alarming as easily when I throttled up from idle, but still got the high RPM alarm when I went above 3200-ish RPM. If it wasn't alarming, the boat runs like a champ. 507 hours on the engine, regular oil changes every season and full outdrive fluid changeout every season (average 50 hrs/season).
Any ideas???
* Fuel/water filter
Any ideas???
