Engine alarm? Where to begin?
Etzler
2008 350 mag tow sport in a Ski Centurion. Cruising at 3000-3300 rpm I get a solid alarm. It won't go away until I pull the power back to idle. Temps and pressures are all good. Will this set a code in the 555 ecm? Possible trouble shooting ideas? What sensors tie into the alarm?
could be any of the following switches/sender that are alarm related:
water pressure sender
water temp switch
oil pressure switch
lube reservoir switch
post your serial number. that will help us help you.
