Engine Align
brodie123
I've read some good posts here on aligning the engine - mercruiser I/O and will be following that advice.
Question is, before I raise/lower the engine from the front - should I not back off the rear mount bolts to allow some movement without snapping something?
Thx!!!
Don S
Re: Engine Align
If you have to ask that, maybe you shouldn't be working on your stuff. Some things are just obvious.
boat127
Re: Engine Align
i leave the rear mouning bolts torqued to the proper torque spec. if you adjusted the front mounts while the rear mounts loose you wont get it aligned properly because lets say you got the front mount to where the aligntment bar slides in and out properly then you torque the rear engine mounts it can throw off the alignment
brodie123
Re: Engine Align
Thanks Boat127 - I appreciate the appropriate reply.
It's like we teach our kids... if you can't say something nice or helpful..... the rest is "obvious"
This is why I wasn't too sure - throw the alignment vs torquing the rear mount.
Obviously I won't be raising the engine to a far degree - but is there anything else here I need to watch out for?
boat127
Re: Engine Align
i would check the condition of the engine mounts, the coupler gimbal bearing as well all the bellows and u-joints while the drive is off. put some grease on the end of the alignment bar before you stick it in then when you pull it out you can see the spline impressions from the coupler.
EerieDogg
Re: Engine Align
The rear mount bolts consist of a fiber washer and a spring. Take it from there
Thx!!!
achris
More fish than mountain goat
Re: Engine Align
The rear mounts are rubber and can take quite a bit of movement.
ken_23434
Re: Engine Align
You should not be moving the the front of the engine much to begin with. Half a turn on the nut can make a difference in getting a good pattern on the alignment bar or not.
bigskiohio
Master Chief Petty Officer
Re: Engine Align
Man your two cents were not even right, if your comment is not going to help
SHUTUP!!!! WOW , I GUESS I DID THE SAME!!!
brodie123
Re: Engine Align
Thanks all - I appreciate the insight and will do exactly that.
This has a been a great project boat and learning experience for me. Been lots of fun!
Thanks again
