Keyboardman
- Joined
- Sep 10, 2015
- 364
I've installed a new 2.3 in the boat and need to align the engine and install driveshaft seal and gimbal bearing before installing the out drive. When I removed the outdrive the gimbal bearing came out stuck to the driveshaft. The tool I bought needs a hole drilled in it for the bearing cup to work. The instructions say to insert the rod into the old bearing and coupler till it bottoms out and mark the rod at the bearing. Now, if the bearing is already out, how should I go about figuring where to drill the hole? Also, if the bearing and seal need to be in place to align the engine, how can I install the bearing without it already aligned? Thanks.
