Engine alignment issue
Jerryh3
In the course of trying to get the engine aligned, I may have turned one side of the front mounts more than the other. The bar goes in and out with moderate resistance, but I would like to get it better. Is counting the threads on the mounts and making them equal an acceptable way to get back "zero" or is there another way?
Re: Engine alignment issue
Ayuh,... Generally speakin',... Nothing in boats is absolutely symmetrical,.. Ever...
Thread counts are meaningless,... The alignment bar is where the true answer comes from....
Jerryh3
I figured that. I just went out and tried it again. It takes a good yank to get it out and the striations are very pronounced on the top of the bar and grease is barely touched on the bottom. Looks like I have some work to do tomorrow.
cr2k
You need to lower the front mounts a little.
Jerryh3
Bought a set of stubby "service wrenches" from Harbor Freight. Much easier to get it those tight spaces with them. Went down a full turn on each. Slides in and out like butta now. Well, almost.
NHGuy
Hey I like butta, I'm from Boston.
