midnightrider1818
- Joined
- Aug 17, 2009
- 190
Ok so I'm getting ready to replace bellows,lower shift cable, update shift shaft bushings to gen 2 style and replace senders. First thing I did is check alignment. Drive came off a little hard. Of course it's a little off. Slide in a little hard. Good spline contact 3/4 of the way around on top not so good on very bottom. So I know the front of engine has to come down right. Can you make that up with the gimbal bearing. In other words will it gimble up?. Also can you take instead of front of motor down can you take back up. Never adjusted alignment before so any tips or tricks on this?
