midnightrider1818
Thread starter- Joined
- Aug 17, 2009
- 190
Well I'm on to engine alignment now. Kind of wish I would have done this while I still had bell housing and manifolds elbows off. Here is my dilemma. I had heavy spline contact on top and barely on bottom. Also installed new gimbal bearing and yes I align that with coupler everytime i adjust mounts. Anyways, I could get bar in but it went in hard. I moved front of motor down probably 5 turns on each mount maybe even 6 lost count. Spline contact is better still a little light on bottom and bar is going in easier but definately not with 2 fingers but a slight pressure. Wants to come out alot harder for some reason. Not sure if grease is hanging up on seal or what. I also noticed port mount is lower then starboard mount. What I mean lower is bottom adjusting nut. Is this normal?. Also what I did is mark bottom nuts relative with motor mounts to keep even. I am not using a hoist as nuts are moving very easily. Up and down. Just curious as why I'm having a hard time setting alignment and why I am having to go down so many turns. Cant get to back mounts to check condition with manifolds on but everything else seems good. Any pointers
