Engine alignment
Kubaat3lover
I’ve checked my alignment today, does it look good?
Bottom side is more significant than the upper side. Put the engine lower ?
I would think up
If the marks are 100% top and bottom then even up both sides just slightly. If its a bit off to one side then one side more then the other
"nut mounts"?
The large nut under the mount turn up 1/2 to 1 turn
achris
More fish than mountain goat
.... If its a bit off to one side then one side more then the other
Never raise the sides unevenly. If the witness marks are uneven on the sides (a side to side misalignment) it means the engine is cocked in the horizontal plane, left to right. The most usual cause of that is an uneven transom thickness, or the engine side mounts have been position off centre and are 'pushing' the engine sideways.
No kidding dude, but we don't know if one side has moved more then the other over time. So if there is NOT a straight up/down marking, then one does need to move more then the other. Most probable cause is not always what has happened. Could be over time one mount softened more then another, it's wood, glass and time
Settle down, no one including me knows everything, so lets offer some advice and see what turns out
achris
Sorry AD, I thought you were advocating a deliberate change to force a 'roll' on the engine, with respect to the transom plate.
'Tis all good. :)
Chris.....
Kubaat3lover
Guys, 1 thing which confuses me. If the bottom marks are stronger, doesn't it needs to be lowered??
Kubaat3lover
Achris, youre the best as always... wish me good luck.
Im on my way to the boat.. take care
tpenfield
Actually the opposite . . .
This diagram may help understand.
So, the engine mounts need to move in the opposite direction of where you see the marks.
Sorry @achris - Looks like we were both replying with the same sort of thing :LOL:
Kubaat3lover
OK here is the report because I’m very little space to operate with the Wrench I did twice 6x 1/4 turn of the nut.
There is little pressure when removing the tool , is that correct? I make a video how does it look like
If the marks are not visible on the video I can post the photos
New gimbal bearing I think?
If so, insert bar and smack it with your hand up/down/left/right a couple times. Remove and reinsert and see if its a bit easier. Need to center the bearing after each adjustment
It should go in with 2 fingers
Kubaat3lover
Gimbal is the old one I just removed the drive to change UJoints and bought the tool to do the alignment. First time for 3 years since I own the boat, I’m sure prev owner never checked that,
