Re: engine and outdrive swap question?
Betayv - I took my complete alpha 1 gen 1 engine package including outdrive and gimbal housing out of my 1985 boat and put it into my project 1996 boat. It can be done. Search my past posts and you may find some questions I'd asked on here about it (I have 2 boats, so most of my questions on here won't apply)
Anyway - the holes in the transom are the same, so your outdrive will line up. You just have to take out your entire transome assembly and use your whole engine package (engine, transom assembly, and outdrive). So, you'll strip the new boat bare, and then take absolutely everything off of your old boat and put it into the new boat. You'll want to make sure you get the engine aligned properly.
As for the wiring, the engine harness/plug may not line up the same, but hte colors should be the same, so you can just keep your plug and splice the wires from the new boat into the wires from your engine package (if they don't already line up).. it's no big deal... you can find the service manual and check wiring for your new boat vs the old one and see if there is much difference..
You'll need a new gasket for the transom (it's cheap) and may want to change out some maintenance items while you have it all apart (like the lower shift cable)
