- Joined
- Apr 17, 2002
- 71,465
Re: Engine Back in, Bunch of new parts.. First sea trial today. Running rich with a k
Ayuh,... I'd Hope the compression tested was pooched, 'n try another 1...
I'd also say the carb still needs some serious Tunin', atleast, maybe deeper...
Started the boat today. It fired first click of the key.
Pulled the plugs..Completly black, sooty..a mess. They are only 1 month old..used for an hour boat ride (THE last boat ride)
The engine still had they funny knocking sound. Use a stethoscope..couldnt pin point the noise. Wasn't the flappers (wish it was, thanks for having me check).
Did a compression test.. Ready..? 60psi on all cylinders. Each Cylinder was within 1 psi. I rented the gauge from Pep Boys. I made sure the fitting went in as far as it could go by hand. 60 psi.
Is that possible for them to all be that low and run like it did? Or start first click?
See the pic of the plug. Hurricane is on its way, so I screwed the plugs back in, put the charger on and covered it up nice and tight.
What do you think?
Thanks,
Joe
