Engine being Removed - which Winterization steps apply?
Chavez1978
I have a 1995 bowrider, w/ a 5.7L Mercruiser V8 Serial# OF438792, Alpha One Gen II outdrive
I'm removing the engine this weekend to repair weak transom. First, a quick thank you; I have read the very helpful posts on that subject that suggested the lableling, photos, videos, manuals etc....thank you all.
I've also read many winterization posts, but wanted to find out what considerations I should take since the outdrive will be removed, and the engine essentially will be drained during removal. Since the engine will likely sit on a shelf/pallet for the coming 4-5 months give or take is there anything I should do in terms of winterization or upkeep for it's shelf period? I'm not asking about oil changes, sparks plugs, belts or any other considerations while I have it out so much as ensuring I leave it stored appropriately.
Thank you.
Grub54891
Re: Engine being Removed - which Winterization steps apply?
I'd say winterize as if it was in the boat.......
Thank you.
Ayuh,..... Make sure it's Absolutely drained, 'n yer Good to Go,...
Essentially ain't good enough,...
If it's gonna sit longer, pull the sparkplugs, 'n shoot some oil in...
Chavez1978
Fogged the engine and pulled drain plugs...drained, then poured some antifreeze down hoses....hope it does the job. Fingers crossed.
