Engine bolts
mippel
Hello All,
I broke a bolt that holds the impeller housing together. Are the bolts that are used in marine engines brass? Could I go to a hardware store, try to fine one that is the same size and use it? Or is there something else done to marine hardware?
Thanks in advance.
Brewman61
Ensign
Re: Engine bolts
Make it easy on yourself, and get to a Volvo shop. They should be able to get you the correct part.
Don't know Volvo, so not sure how easy it'd be to find that at a hardware store.
Should be plenty of places in your area that stock Volvo parts.
mippel
Re: Engine bolts
Sorry about that Don. Just didn't want to screw it up.
