dnero20431
Thread starter- Joined
- Aug 24, 2003
- 1
tahatsu 40hp 1997 ,has auto oil injection.<br />problem .. engine runs fine up to 300rpm,then the buzzer goes off in remote control. when i put shift lever in neutral ,wait 30sec. the buzzer goes off.. i have had the water pump completely replaced. water sensor replaced.. have been told that the oil sensor may be bad. oil injection seems to working fine ,oil level drops as the engine is running. i was told to disconnect the oil sensor and disconect the oil injector system.<br />question is ... i can find the oil sensor,, and i don't know to turn off the oil injector system,, and just mix the oil with the gas. the buzzer is driveing me crazy. i can run engine all day below 3000rpms and have no problems, thank you
