engine/carburator specs for johnson 40 & 50hp
MississippiRiverRat66
First of all I am looking for the information on on the differences between the 40 & 50 hp 45 ci OMC engines. My goal here is to try to do a low cost upgrade to a 40+ hp motor with out rebuilding/changing the pistons and crank...just yet. Any information or suggestions would be helpful.
tashasdaddy
Re: engine/carburator specs for johnson 40 & 50hp
what year. 80's and up use the same carb body, different jets, but you also have to change the link n sinc. you won't get much doing it.
tashasdaddy
your best solution, is to fine tune your boat and motors set up. proper balance of load in boat. proper height and tilt angle of the motor. proper prop for the load.
