Engine cleaning found loose altenator wire
d3nnisc
Hi,
I was wondering what is the best way to clean your engine.
I recently purchased my first boat and noticed a good amount of rust on the outside.
Also getting a minimum amount of oil in the bilge what also good be left overs from the oil change that was done recently.
To make sure i want to clean the engine and the bilge.
Thanks
Dennis
tpenfield
You could use an automotive engine cleaner and then a bilge cleaner afterwards to get the bilge clean. For the rust you could use a rust reformer and then top it off with black paint. Rustoleum is fine.
d3nnisc
thanks Ted, yes i was looking in to an engine cleaner but problem with most of them is that you have to rinse them with water after.
Is that a problem?
tpenfield
Is that a problem?
You are going to have to rinse it with something and water is about the best thing to use. You will want to blow out the standing water on the top of the engine, etc. with your air compressor or leaf blower.
Put some plastic wrap over the air intake to the engine before you do the cleaning and throughout the rinsing, so you are not getting any water inside the engine.
d3nnisc
I cleaned the engine and the bilge ran the engine for over an hour and nothing so probably some left over dirt.
Found something else tho, the alternator was changed back in june but now i found a lose wire coming from it.
In the manual its says this wire goed to the plug. Does anybody know what its for?
Bt Doctur
Your alt should have 4 wires a large Red or Orange , large Black , a small Red and a small Purple the small wires gp to the alt regulator for "sense" and " excite"
d3nnisc
Is it a big problem if this red-purple cable isn't connected?
And where is the alt regulator located?
d3nnisc
Thank you, I have that as well in another wiring diagram is saw that it splits to tot starter solenoid and to the harness. But wat does it do? Nothing on the boat isn't working.
