100333624
Thread starter- Joined
- Apr 24, 2012
- 205
Well it looks like its the beginning of the season, finally! So I got my boat out to de-winterize it only to start off with a bit of an issue... After about 8 hours of working on it I finally found my problem, a clogged fuel line with plastic from the inside lining blocking flow of fuel from the tank to the fuel bulb. It drove me insane because I coincidentally changed the fuel filter this week and thought maybe I messed something up there. Anyways..
So I got it fixed and the engine fired right up (1995 Yamaha 115 2stroke) After running the motor for about 10 mins I pulled out my laser temperature reader and pointed on the cylinder heads beside each piston. Standing behind the engine obviously, I noticed the port side cylinder bank running about 10 degrees F cooler then the other side cylinder bank. After about another 5 minutes all the pistons seemed to have roughly the same temperature more a less (124 F) plus or minus 2 or 3 degrees, but the starboard side top cylinder was about 10 degrees hotter (132ish) The engine was still very warm to the touch (not HOT) even after an additional 10 minutes of running. I ran it in a tank not on muffs btw... Ran my bro in laws XR6 yesterday in the same tank, the block got really hot to touch in 10 minutes, and pretty much boiled the water in the tank lol... anyways moving on...
So after experimenting with temp I pulled the plugs and did a compression test. Plugs looked a little oily and good. Port side top ~125, bottom 130, starboard top ~127, bottom 125. Seems pretty good and close enough to each other. Now my main question is what is considered "high compression" in relation to running "high octane" fuel. I'm not talking about like race engines or anything but just in general. After speaking with some people I was told running high octane in low compression engine would cause damage, and running low octane in high compression engine would also cause damage. So what do I do? I was also told that running 87 octane supposedly is causing Yamaha 2 stroke V engines to break rods? And that I should be using premium only, but then a rebuilder told me its the worst thing to do. Actually he advised of adding another gasket to the cylinder heads?
I normally run 87 octane and add just a touch of seafoam in the tank to stabilize fuel and clean carbon, but I was also told even that is too aggressive for 2 strokes and will eat away headgaskets more quickly? I can live with using a regular fuel stabilizer, and I can live with putting premium in my tank. I do have a water separator installed in the boat as well. But the question is: what is the "ideal" octane for what type of engine? How do I know what octane gas to use? I know its good to use high octane in all the small 2 strokes like mowers, leaf blowers, chainsaws etc.. but outboards?? My engine runs excellent and I want it to stay that way
