Triple502
- Joined
- Oct 22, 2016
- 66
I recently replaced a 1995 Mercruiser 5.7, 260 hp motor with a new long block. Motor seems to be fine except that it is running a little warmer than the specs call for. I replaced the T-stat (165 deg) twice and put on new impeller and pump housing. After all of that I still get the same reading on the gauge, 185-195. The only other thing I can think of is the power steering fluid cooler or the sending unit. I should note that before the old motor locked up, it never went above the 165, so that leads me to believe the intake hose is fine. The manifolds and risers are brand new as is the circulating pump on the motor. I did reuse the intake manifold but had it checked at the local machine shop and it was given a clean bill of health. Anything else? The boat is in the water now and the 5.7s are mated to Bravo II drives. Is 195 too hot? It never goes above that temp and I am operating in brackish water in southern MD. Thanks.
