hammerdog57
Thread starter- Joined
- May 9, 2018
- 7
i have an alpha one gen two that is making a rattle metal sound in the drive coupler area. noise is intermitent. noise dose not increase with rpm. or in gear. pulled outdrive and started engine to see if noise went away. with engine started with out the drive installed same noise was there but went away after about 30 seconds of idling. could this be a bad coupler? have already replaced u joints and gimble bearing to see if that stopped noise. noise sounds like sand being slowly dropped in a bearing. engine is aligned and splines look good on coupler.
