Ok, so heres my issue...first of all I'll tell you i have a Merc I/O 185 merc 3.8L GM motor
I took the boat out this weekend and had a problem, boat ran smooth for 3 hours or so and then it started to cut out when I was going 25 and over....??...really strange......i would throttle it forward and plane off and get up to speed and maybe a minute into going at least 25 and over, the engine started to cut out, almost like it wasnt getting enough fuel....it would rev up and down, rev up and down and again so i had to pull it back and basically stop.....it did it numerous times with a few times stalling and when it stalled it started up and idled good, as soon as i gave it some power to get up to plane it cut out.....at first it was ok at low speed so i ran about 5mph back to the dock but on the way it also started to do it at low speed, but not at just idling....it would idle fine. Again I'll say it ran fine all day for at least 3 hours, and also took her out 2 other times this year and no issues at all either time.
I do have a water seperator on it and checked it and it was clean, not sure where if any other fuel filters are located...
Any ideas??..fuel filter? coil?? something electrical??
any feedback you can give me will help out .....
Thanks
Thanks
