Engine Decarbonizing
JimS123
After reading all these oil threads, I got to wondering whether I have been lax in maintenance all these years. Never decarbonized one yet.
The motor I'm concerned about is a 1984 Evinrude 9.9 sitting on an OMC bracket on a 19' bowrider. It has a sailboat prop to keep the rpms higher. I did have some issues with plug fouling the first year, but got that resolved.
The motor is used strictly for trolling at 1.9 mph. It is usually run once or twice a week in season for 4 hours each time. At the end I run her up to full throttle for a few minutes. Originally, it smoked when I did that, but as I said those issues were resolved.
Anyway, last fall the motor turned over 600 hours. My question is should I decarbonmize or leave well enogh alone?
foodfisher
Re: Engine Decarbonizing
Two thoughts. Decarb can't hurt and "if it works, don't fix it"
Silvertip
Decarb will not hurt the engine. If it has never been done, do it. If you see no difference, only a few bucks were lost in an attempt to prolong engine life. However, if the engine has been used primarily for slow speed trolling it will benefit from the decarb process. You might want to check compression before and after.
foodfisher
If it needed it the compression will go up. Captainhook:eek:bviously the answer is yes.
AguaSki
You should see compression increase because your piston rings are sealing better once the carbon has been removed.
Proselect
I just bought a new to me fishing boat last year with a rude 112. I would like to decarbonize it for the fact I am not sure if its ever been done. Can somebody explain how or point me to a good thread. I will do some more searching. I do have the schrader valve on mine.
