Javelin JD
Thread starter- Joined
- May 4, 2013
- 85
OK, so I went out yesterday to try and get a better understanding of what was happening so I could solict further advice from you all. Here's the skinny. Started fine after I primed the bulb. Ran fine, however I didn't run in longer than 20 min or so getting to my fishing hole. Same as returning to the marina. When I got to the waiting area (lot of people on the water, many didn't know how to back a trailer, or load a boat), I idled down and waited, the motor stayed running. After I tied her up to get the truck I killed it, I was gone about 10 min as the wait was still present. It wouldn't start until after I pumped the primer bulb at which it started right up. loaded it onto the trailer and as I was cranking the wench, it died. I didn't need to start it back up as I was already loaded. Would this be a carb issue or should I be looking in some other direction. Thanks for your advice
