Engine fogging question
G22inSC
I am still reading, learning and gathering the parts and supplies for my first winterization this year. I have a '97 4.3 motor with the 2bl carb and electric fuel pump. My question is about the fuel supply while fogging. It seems from reading it is recommended to disconnect or shut off the fuel supply when you introduce the fogging oil into the carb. I can't find any sort of disconnect valve within the fuel lines on my motor. If i disconnect the fuel line from the carb, I am assuming the electric fuel pump will continue to pump fuel.
Would "capping" the fuel line damage the fuel pump that would still be trying to pump fuel?
Would I be better off just leaving the fuel supply connected or maybe I should try to kill the power to the fuel pump?
Is the best solution just to leave the fuel supply alone and just fog with oil?
Sorry for the probably stupid questions...I'm still trying to learn as I go. Thanks in advanced for any insights.
Don S
Re: Engine fogging question
You do not shut the fuel off. As long as it has fuel stabilizer in it, it's fine. Just fog the engine and shut it off. No reason to drain the carb or run it out of fuel.
The bad thing if you did shut of the fuel would be running the fuel pump dry. Not good on electric pumps.
smitty28
Just leave the fuel supply alone...run the motor up to temp, spray the fogging oil down the throat of the carb till the motor kills..fogging complete
Silvertip
Honorary Supreme Mariner
Be sure to add the fuel treatment first so it gets into the fuel system before you do the fogging. You want the carb internals protected.
mpdive
Follow instructions post 1 through 4.:D
G22inSC
Good deal. I was good on the treatment, just was not sure about the fuel supply itself. Thanks guys.
