Engine ground question
charliebabb
Hey guys, I was having some problems finding a ground on my boat. What I did was I connected one end of my multimeter to the negative of one of my batteries and touched around on the boat and found continuity on the engine block. That's what I was expecting. After that I had realized that I had the multimeter connected to the positive post. So I'm getting continuity on my engine block to my positive post on my battery. This can't be right?
Any suggestions?
Thanks for the help
JB
Re: Engine ground question
Sounds like you had your meter measuring voltage rather than resistance, charlie. That would be any boat in my experience. On the other hand there might have been boats wired for positive ground, rather than negative.
Maybe your Hatteras is wired for a positive ground.
bruceb58
Any suggestions?
Its not really a valid measurement. An ohm meter puts out a slight voltage and measures the drop on that voltage. Resistance measurements can only be done on circuits where voltages won't influence the resistance measurement.
hrdwrkingacguy
True...My meter beeps at me in a very condescending way when I measure ohms on a live circuit...:eek:
hrdwrkingacguy
I use this for a lot of stuff at work and around the house and boat...A Fluke usually wont go "poof" unless you out of the voltage range...:eek:
Silvertip
Any suggestions?
Thanks for the help
Look at it this way -- if you had the meter set to DC Volts rather than Ohms, it would have measured 12.6 volts provided the battery was fully charged. You don't have a problem.
wrench 3
Yep, you cant beat a Fluke.
Most of the boats I've had came with every thing wired back to the battery negative. It makes quite a mess and is a hassle when removing the battery for winter storage. So I install a ground buss in a central location and run one ten gauge wire to it. the ten gauger will handle all the usual accessories, just don't hook up a 600 watt inverter or something.
joed
If you had some device turned on then you could get a reading from positive to the engine block on ohms scale. It could have even been through the charging stator coil.
