chartersj
Thread starter- Joined
- May 14, 2013
- 300
The 12+ lift actuator for engine hatch on my scarab 26 is slow. I have hooked it up directly to the battery and works great...after some reading it seems I'm having too much voltage drop by the time power gets to the motor. Some have used 2 relays for up and down functions but have read they can be unreliable as well as they cannot handle the amperage draw the motor takes. I tried using 2 marine trim pump solenoids but I couldn't get them to operate the motor because I assume the motor isn't getting a path to ground...is there a different way I could wire in solenoids to operate the hatch?
