JASinIL2006
Thread starter- Joined
- Feb 10, 2012
- 5,769
Hi all,
The engine hatch on my (new to me) '97 I/O bowrider won't stay up. The hatch is upholstered, about 4' wide and 15" deep, and it currently has two gas springs that say they are rated at 40 lbs.
I can't tell if these gas springs have given up the ghost and should be replaced or if the previous owner installed under-powered spring. If the latter is the case, I would need to select more powerful springs. I haven't removed the hatch and weighed it or anything, and if possible, I'd rather not...
Do two 40 lb. gas struts seem like they should do the job, or should I look at heavier-duty springs, like maybe 50 lbs.? Any downside to using the 50s (e.g., the hatch unexpectedly flying open at speed? launching small sunbathing children off the boat?)?
Thanks!
Thanks!
