Engine Id volvo penta
captmello
Can anyone help? I'm trying to identify the motor in my boat. Its an '87 with a gm 5.7ltr with a 275 vp outdrive with power steering. I've been trying to order parts but having trouble not being sure what I have.
The Tag by the transum has PN 867900 8617
Serial# 724881
The tag on the top of the outdrive reads 853574
also says 275A
Can anyone tell what model AQ???
Thanks for any help.
jerryjerry05
Re: Engine Id volvo penta
Probably 260 D .Most of these used the same parts.The difference between B-C-D were minimal. What parts are you wanting to buy? Jerry
captmello
I was just trying to order an impeller but i figured it out using the part number on the housing cover.
Thanks for the info. After reading hundreds of postings I couldn't figure out the HP rating. The power steering was mixing me up as well. The VP store doesn't list a aq260d, only a and b. A has power steering but a different impeller housing part#, B has my impeller but no power steering. Maybe I'm overanalizing but don't want the wrong parts.
I just bought the boat as a fixer upper and have been working out the kinks.
The Impeller housing seems to wobble and must be hard on the crank bearings so I ordered a new impeller. The old one looks okay in the housing but can't hurt to change out. Any suggestions on the wobble?
I'm pretty sure this has a car motor in it with all the volvo stuff bolted back on. What do you think of that, am I in for problems? I was told the block was the same, I had the heads rebuilt and reassembled with marine gaskets.
My outdrive lift sounds like its laboring, can those be lubed or serviced?
All comments are appreciated.
jerryjerry05
BBBB sorry. It is a chev motor.But it was marinized!!! The lift units can be serviced.I don't think the elec.motor can be rebuilt.The gears and drive components can be taken apart and greased.Jerry
