Engine Info
maliggett
I just bought a little bass boat with a small Evinrude (7.5 hp) motor on it. The model number is E8RCIA. This doesn't seem to quite follow the rules for model numbers so I'm a bit confused. The motor says it is 7.5 hp but the model number implies it is 8 hp. I am also guessing that the "CI" means it was built in '81 and that there is no "shaft length" designation. Is this correct? Where can one get an operators manual and/or a repair manual for this engine?
Thanks for anyone's help. I am a rank amateur at this and just hope it will run well enough to let me putt around in Mission Bay in San Diego.
tashasdaddy
Chinewalker
Re: Engine Info
Yep, it's a 7.5hp. 7 point 5 wouldn't work well in a simple model number scheme, so they rounded up. They did the same with the 4.5 and 9.9, too...
- Scott
