Engine Info???
cscards
Can anyone tell me about my engine? <br /><br />Serial# D621941<br /><br />I know it is a 5.0 mercruiser. How many hp? Ford or Chevy? Any info you can provide would be great. Thank you.<br /><br />One other thing.....With the above info, can you tell what size prop I should have?
Don S
Re: Engine Info???
It's a Chevy<br /><br />ENG: 0D621941 450L100ES 1992 MERCRUISER 5.0LX ALPHA I <br />DRV: 0D636397 5010150ES 1992 MERCRUISER ALPHA 1.50:1 <br />TRN: 0D645368 6010000ES 1992 MERCRUISER ALPHA TRANSOM <br /><br />You should look for service manual #15 from Merc, PN 90-816463
cscards
Re: Engine Info???
I pulled the plugs, they are AC Delco (MR44T). I cross referenced this to a Champion RV12C. Should this be fine?<br /><br />Do I have a Ford or GM? Being a 5.0 I figure it is a Ford..........
Don S
Re: Engine Info???
If you look at my first reply, the first sentense says "It's a Chevy"<br /><br />No champion is FINE in a marine engine. Stick with AC, NGK, Bosch, anything but Champion. They cause more problems than they cure.
cscards
Re: Engine Info???
Thanks Don S... I must have read your above post ten times, sorry about missing the IT'S A CHEVY LINE........Thanks......<br /><br />Do you know the plug number of the Bosch I should use?
lilmandavis
Re: Engine Info???
seemd like the bosch's just drop thier ceramic tips down into the cylinders!!! happens alot seems like
Don S
Re: Engine Info???
We've been using Bosch and NGK plugs for years on about 50 to 75 boats a year and I've never seen or heard of the ceramic tip falling off on any of them.
cscards
Re: Engine Info???
Champion exchanged today for Bosch Platinum...Thanks Guys....<br /><br />Next...How much oil does this engine hold and what oil is the best to use?
cscards
Re: Engine Info???
Oil, how many quarts do I need to change it? Also, what type of oil is best?<br /><br />Does anyone know how much horsepower this engine puts out?
