jonny rotten
Thread starter- Joined
- Jan 8, 2012
- 380
1998 Merc Gen 2. Engine going in after repair. Near impossible to reach the back/sides of motor after install. What I know I need to do is the 3 ground wires on the port side rear engine block stud and one on the starboard rear block stud, power to starter, all with motor hanging. Water hose on transom side. Also I believe the trim sender bullets get connected to purple and blue bullet connectors in wiring harness?, does it matter which way? Where do the other trim wires get connected? Are they on the motor somewhere and can be done after install? Anything else so I'm not lifting motoer back out because I cant reach a connection
