Nextelbuddy
- Joined
- May 4, 2020
- 156
All right engine is in.
Removed blown non vortec 350 and replaced with fresh full rebuild 350 5.7 vortec.
We use the timing lights at the thunderbolt 5 ignition and base timing mode and set it to 10° initially and my engine builder said he felt comfortable with 13° BTC so that's what we set it at.
Then we took it out of base timing mode and put the revs at 3,500 RPMs we're seeing about 25 degrees of total advance.
They said we could go up to 30 but I said let's be comfortable and safe so we left it at 25° total advance.
Boat:
- 1996 Sea Ray 210 bow rider
Engine:
- 1409 Edelbrock carb 600 CFM
- summit racing vortec intake manifold
- Comp cam Marine cam
- vortec heads
- alpha 1 Gen 2 1.62 gear ratio
- quick silver stainless 14.25x19p 3 blade prop (a few dings)
Max RPMs of 4700-4800 RPMs and gps verified 50mph. Boat definitely got out of the hole quick and got on plane easily. Reached max RPM with ease almost too easily
Since this is a vortec engine, do I still have to abide by the 4400-4600 rpm range of the older non vortec engines? Or can I go up to 5000 RPMs?
Asking because I want to change my prop out just want to figure out which prop to go to and how it will affect my max RPMs
Was really hoping to hit 55mph in this boat with this new engine.
Boat:
Engine:
- vortec heads
