engine kill switch?
betayv
Hello guys 1987 searay 5.7 I/O, I want to install a kill switch for security purposes how can I do that, again thanks for the help.
Bt Doctur
Guessing you want to hide it someplace. could install a switch in/near the engine compartment or under the dash , or wire 3 acc switches in series .
HT32BSX115
Howdy,
You can easily wire a "kill switch in the circuit. It can be basically anywhere too........ you can put it in the engine compartment or under the dash.
The following diagram shows the wire where you can place the switch:
Just place the switch anyplace in the purple wire. Opening the switch will remove power from the ignition switch. The RED/PUR wire would also work too.
The purple wire is usually where the "kill-lanyard" switch is wired if your throttle quadrant is so equipped. (pretty good idea to have one of these to "kill" the engine if you fall out of the boat!)
If you just want to prevent the engine from cranking, you can place a SPST (single pole/single throw) switch in the YEL/RED wire (in series) .......... which is also used to prevent starting in gear. (neutral safety)
Cheers,
Rick
betayv
thanks I want to put it under the dash a on/off switch will works for that idea.
