frustratedboater
- Joined
- Jul 10, 2007
- 436
Guys,
After de-winterize my engine and had some idling troubles. I had replaced the head & water plate gaskets, thermostat, new water pump last season, New carb bowl (corrosion) as well.
I am experiencing very choppy, bucking-type idle. I need to pull the choke knob a little to keep it running in the tank. I had used compressed air in the carb in all the known holes, ports, jets, and still the same! I even took apart the choke and blew it clean. I am assuming that it is carburetion..?..?
I would appreciate ANY help with this.. Thank you!
~FB~
~FB~
