texantommyray
Thread starter- Joined
- Apr 13, 2009
- 5
I have a 1987/88 Yamaha 90 and had it on a 16ft bow rider. I took it off and mounted it on a 20ft pontoon. It ran great. I have always replaced the lower unit fluid and propeller every year. I start it up every week or so.
It was running great but i noticed the RPM's at WOT were 3800. The prop was 13 1/2 x 19pitch. So I bought a 14x13 and the RPM's went up t0 4800. I called the mechanic and he said bring the prop back and he would replace it with a 14x11pitch. So I did. Then it ran 5600 RPM's at WOT. I was told that is where my motor needed to be. So I ran it WOT for about 20 minutes to get to the other side of the lake in slightly rough water and when I started backing throttle down I heard a loud knock/clatter sound. It was still running but knocking pretty bad. I drove it at around 1800 RPMS at a really low speed just to get back in to my slip. I tested compression and found (top to bottom) 120, 85, 120. I took head cover off and when I turn flywheel they all move up and down freely and all look good, except the middle piston doesnt come all the way up. It stops at aboutb 1/4 inch or so from the top.
Piston doesnt seem to be loose from this side.
I probably should have left the prop alone. It was running fined for a month before this happened.
does anyone have any ideas of what this could be?? Loose rod maybe??
Thanks
Tommy
Thanks
Tommy
