engine miss after installing vro to pre-mix pump
ddyk
I have a 98 200 hp johnson that i replaced the vro pump with a stand alone fuel pump. After installing the pump i now have a very noticeable miss at all speeds. This is with the muffs on so i'm reluctant to take it to the lake. I have no idea what I may have done during the install, the bulb pumps up fine, so are there any ideas out there what i need to look at? Any help will be greatly appreciated!
Honorary Supreme Mariner
Part # of the pump you installed.----Sourced through a dealer or somewhere else ?
It could be that there is an issue with crankcase compression.----It is the PRESSURE that drives these pumps.-----How did motor behave with the VRO pump ?----Did you find something wrong with old pump ?
ddyk
It ran fine before other than it was trying to run out of gas ( i had to keep priming the bulb for it to stay running) It didn't have this type of miss before. I haven't had a chance to look at the old pump yet.
Vapor separating tank------Your motor does not have that item !
Chris1956
My '98 Johnny 150HPV6 has an intermediate orifice on the carb or throttle body. They are open to the air. Give it a blast of spray solvent and see if that works. It is a brass tube under the air box.
ddyk
ill give that a try, thanks
Then get rid of that fuel pump.-----Sounds like it is clearly the issue !
