engine miss under load
zindale
Re: engine miss under load
well its me again.I am rebuilding powerhead, going 20 over with wiseco forged pistons, have read that force was known for ring breakage, is what happened to mine. will the wiseco pistons still have ring failure? and was informed while boring block to chaffer intake and exhaust ports so rin<br />g wont grab is that a good idea?
zindale
first i would like to thank you guys again for your help. finally got engine rebuilt not to bad once i found the parts and a machine shop to do work. but still have same prob. i even bought a couple cdi mod. and swappped with no effect. question i have is the stator wiring the wires are numbered 1-6 and books has them listed 1-6 or color codes i wired to color on diagram in book and on block. but is not numbered in order 1-6. still starts and runs easily only at 2200 rpms does it start its missing real bad like more than one cyl at a time. i think previous owner had same prob i found a stator and trigger in boat. stator deff. bad has burnt wires. sorry so long but wanted to not forget nothing.
