JASinIL2006
- Joined
- Feb 10, 2012
- 5,744
Re: Engine mount lag screw broke - how to remove?
Frantically Relaxing, what are those called? I think that's an interesting idea and would maybe be a nice alternative to lag screws.
I have both epoxy and poly resin on hand, so I'm OK with either, I just want to use whatever is strongest and will bond the best.
If I'm bedding studs or lag screws in new fiberglass or epoxy, how much penetration do I need into the engine mount? Is 2 1/2" enough? What sort of fastener material should I be looking at? Zinc-coated? Stainless steel? Galvanized?
Thanks,
Jim
Thanks,
Jim
