smiles16
Thread starter- Joined
- Jul 25, 2016
- 186
Finally got to test out the used Mercruiser 120 I dropped in the boat and am concerned about some engine noise I am hearing. Also, I know my shift cable is worn and needs replaced, but I am not sure the shift interrupt is working properly. I know the switch is good because I can push in the plunger and it kills the motor. I think there may be something going in with the linkage adjustment. I posted two videos on YouTube and have the links below. Could you guys share your thoughts on this? Is the noise normal engine noise or something to be concerned with? What about the linkage?
Thanks
https://youtu.be/03LgYVuZqQg
https://youtu.be/clQVFHARcco
Thanks
