kwoolard
Thread starter- Joined
- Feb 9, 2003
- 420
I purchased this boat back in June of this year. It is a 1999 235WA Sea Pro with a 125 gallon tank, 5.7L 350, Alpha Gen II with a 2 barrel mercarb. I am currently running a 19 inch pitch propeller and have a WOT of 3900-4000 rpms with 4 people aboard. Over the past week I changed my plugs, installed new riser and manifold gaskets and serviced my outdrive. The problem I have, which existed before I performed the maintanance work, is that when I push it to WOT I get a rattling noise from the engine. The best way I can describe it is putting a couple of steel BB's in an aluminum can and shaking it. It is only making the noise when I run high rpms, ie., above 3300 or so. Does anybody have any idea as to what this noise is? The engine runs great, idles great, I just can't get the recommended WOT and have this engine noise. I am going to try a 15" prop this week to see how that helps the WOT, but my main concern is the engine noise.
Thanks
Thanks
