engine noise
tuxcedo88
200 evinrude ( has rebuilt powerhead ) starts and runs o.k. However in powering up, it has a rattle and some vibration. the prop is fine , could there be something loose in the mid or lower unit. When the engine was rebuilt the mechanic changed the water pump impellar and the fluid - but thats it in the lower unit. Could there be a bearing or bushing in the drive assembly if worn would give this effect :confused:
hondon
Re: engine noise
Alot of possibilites here.Anything from poor timing to a bent prop shaft.Give us some specifics and maybe we can help.
tuxcedo88
Re: engine noise
hondon, thanks for your reply, I know there could be endless possibilities, I am going to take off the lower unit and have it checked next weekend I'll post the outcome :eek:
tuxcedo88
Re: engine noise
just thinking, Don't know if related- idles good rpm range 1000-1300 motor shakes after that runs smooth? dirty carb? :eek:
