yamaha701986
Thread starter- Joined
- Jun 12, 2010
- 5
my yamaha 70 1986 runs fine up to 3500RPM. After that it wants to cut out. It still keeps on running, but I pull back on the throttle to make it run smooth. All I can get out of it is 3500RPM. I cleaned the fuel filter, installed a new primer bulb on fuel line, check the fire on all cylinders and drained the gas out of the two carbs. (I could not get to the bottom carb.) It ran fine last summer, but I put a new impeller in last week because the horn went off, the first time I put the boat in this summer. After installing a new primer bulb the bulb still is not very hard. Any help is greatly appreciated. thanks
