ENGINE NOT STARTING...KICKING MY BUT
prc03sx195
I have an 03 I/O mercruiser 4.3 and just tried starting after sitting 3 wks. Checked fuel at carb inlet and it is getting it from pump. Checked coil for voltage and it is getting 12 v on purple wire a ign coil. Checked for continuity at ign coil and it is not open so I figured that could be ok. Pulled plug and laid it against ground surface to check for spark while cranking and there is none (is this a good check)?
What else can I check and where do I go from here? This is killing me. Thanks for the help.
Rick Stephens
Need fuel and need spark to run.
No spark means you have a bad connection or a failed part. To get good answers you should probably post serial number and type of ignition.
Do you have the original 2 wire ignition module or the updated 3 wire?
prc03sx195
How can I tell if I have two wire or three wire? I'm pretty sure it is the original equip since I owned it from 06 and on.
You pull the dizzy cap, then pull the rotor and look
prc03sx195
ok I can do that but the last time I tried to remove the distributor cap I could not get it off, it seemed like it was sealed on the housing. So what will this tell me and how does it influence the trouble shooting? What am I going to knowing if its 2 or 3 wires?
I don't have a wiring diagram so are there any lockouts or devices that would cause the ignition to not function?
If its 2 wires, most likely it failed and you need a new ICM.
prc03sx195
It is a 2 wire. Can the boat dealership test these module's? Or do they just buy it and hope for the best? How can I be sure if they can't be tested, these are not cheap items?
nola mike
Is this a tb-5?
prc03sx195
I am not sure what a tb-5 is? The engine S/N is M323847 and the model is MCM 4.3 L. It is a 2 barrel carb with 2 wires coming out the dist. Thank you
nola mike
Thunderbolt 5 ignition. Looks like you have an MPI engine, which is a different beast than the standalone systems... But you say you have a traditional coil?
prc03sx195
It has a traditional ignition coil and it also has an ignition module or amplifier. The engine model is MCM whatever that means.
prc03sx195
Ok, just saw that I have a tb-5 ignition. So now that I know that where do I go from here. Thanks
poconojoe
I have a 2003 4.3
I was able to pin point the problem by going through the TB-5 troubleshooting chart.
If it's the ignition module under the distributor cap, it's not expensive. I paid $46 for a Mallory unit 3 years ago.
The hardest part for me was getting the rotor off. Apparently they are glued on from the factory. I had to cut the rotor in pieces to get it off while being careful not to damage the shaft.
The ignition module was pretty easy. The old one on mine was a corroded exposed circuit board. It had two wires. The ground connection was through one of the mounting screws.
The new one was a sealed unit with a third wire which was the ground. I grounded that wire to the block.
While I was at it, I changed out the cap, rotor, wires and plugs. Nothing like a good tune-up.
nola mike
I linked it above...
Strange though, when I plug in your sn I'm getting an MPI engine. Is yours original?
prc03sx195
I brought this boat 3-4yrs old. Nothing has been done since I owned it. The s/n could be off in the 3rd digit, it's rubbed off partially. Does that change my diagnostic work on the ignition system? Thanks for the help.
nola mike
Yes, follow the tb troubleshooting guide above...
