DangerMouse1
Thread starter- Joined
- Jul 28, 2020
- 38
I have a Mercruiser 5.7 V8, and I'm having an issue with starting. I couldn't find a similar issue to this on the forum.
The engine had been running fine all summer, and I changed the outdrive mid-summer (alpha one gen 2) and had no issues. Now all of a sudden I am having issues starting. It makes a loud click noise, no cranking. I cleaned the starter relay solenoid connections (the one on the top of the engine block, not on the starter itself) and also all the battery terminals, connections and ground on the engine block. I got autozone to test the battery and it is good.
So I still couldn't get it to start. I decided to crank the crankshaft by hand and turned it a little, and the engine then started up immediately when I turned the ignition. I stopped it and it started up fine a few times after that. Then after 15 minutes I thought I would try again, and again the click noise when ignition on, no cranking/starting. Again I turned the crankshaft by hand, and it then started no problem.
Not really sure where to go from here. Anyone had anything similar or any suggestions. Thanks in advance.
