Hi, I am a real novice when it comes to Outboard engines. I have a 35 HP (although the paper work says it is a 26HP) Mercury. I had it serviced this year and the gent at the Marina suggested I remove the Oil system I had as it was quite old and parts were no longer available. I said ok and now I have to mix my oil with the gas. Not a problem except now I have the warning noise that appears to come from the throttle control area. The guy at the Marina tells me the engine must be over heating and I need to change the lower unit or something. Does this make sense to you pros? Thanks.
