Engine parts from a '56 ford
ggk1
So I currently have a 1956 f100 that I don't ever take out because it needs new brakes. I just bought a boat with the mercruiser 470 and from what I understand those were made by ford? Or close to them? Anyways, my questions is, are the parts very interchangeable? I need a new starter on the 470 and figured I could probably steal the one from my truck to replace it with? Is there a problem with this?
"G"
Re: Engine parts from a '56 ford
GGk1-
You mention a 56 Ford then talk about a 470 Merc engine. Were you thinking interchangeable parts? No... I hope.
The 470 is an aluminum engine made exclusively by Mercruiser. The head is cast iron and off a 460 ford. They used that head so that so they could get cross flow ventilation, power and economy. They made a 485 too but I think it's nothing more than a 470 with a 4bbl carb. May be wrong there but it's not important for this discussion.
As for a starter I don't remember if it was Ford or not but be very careful! Marine parts are spark protected and one off the shelf at your local NAPA dealer is not. Don't skimp on buying a marine starter, even if it's a rebuilt one. The risk is not worth a life if the spark from the commentator meets gas fumes.
If you are savvy in rebuilding starters that's what I'd do. Most suppliers will have brush kits for marine starters. Undercut the commentator with a hacksaw blade, then dress it up with some emery paper on a lathe or a drill press. Test it for shorts and reassemble her. It's not that tough.
dan t.
the motor in your pickup is a 272 or a 292, old inefficiant and HEAVEY, marine exhaust manifolds would be collectors items if they can be found at all. if your truck is in any kind of decent shape you can sell it for more than enough to buy a used modern marine power package
Don S
Only thing Ford is the head, a 460. The block is aluminum manufactured by Mercruiser.
