Engine Popping Noise
achris
More fish than mountain goat
Re: Engine Popping Noise
That was about 1 knock every second, the engine was doing about 600rpm, which means a knock every 10 revs... so nothing engine, or it would be more frequent... drive gears are 1.5:1 (20/22 teeth), so each tooth meets the same tooth again every .... 10 revs... :rolleyes:
Pull the drive and see if it still does it... One of the things it could be is a tooth missing in the upper drive... Removing the drive will isolate it... Also pull the plugs and do a compression test and 'read' the plugs... You can garner a lot about the combustion process from the plug firing ends... When you pull them, keep a note of which pot each plug belongs in...
Chris.....
pennyduke
The boat is in the water at my slip. Should I do the compression test first or haul it out and pull the drive? It really sounds like a popping in the motor somewhere.
achris
Do the compression test, that's easy... Then haul it out...
Idlespeedonly
Kinda sounds like a backfire. You can pull plug wires on at a time and see if it goes away.
achris
It's too regular and, at the end of the video as the engine speed increased, changed exactly with the engine speed... It's not a backfire..
Running the engine with a potential drive problem like that could easily lead to damaging other things. If the drive completely lets go it could lock up and destroy the coupler, not to mention that all the metal from the top box will drop down into the lower and render that useless too.... Pull the drive and fix it.
pennyduke
I'm all for not blowing something up. I will pull it out Friday and report back this weekend. Thanks for all the help...
