hi everyone
new here..
I have a 1991 evinrude 20hp doesn't want to start, its starts sometimes but cutoffs when you give it gas, but never had a chance to put this baby in the lake..i took it out to the lake and it didin't want to start..the fuel line was leaking by the primer bulb so i came home put new clamps on and start it and it fired up ran it for about 5 min, shut it off and start it again and it started find.
Two days after i was getting ready to got out to the lake it didn't want to start, I really don't know much about boats or boat engines, but as i can see there is a leak coming from the fuel primer solenoid, when you choke it at the ignition you can see fuel squirting from the solenoid on the red valve, so what i think it might be is that I 'm losing fuel pressure and not starting..by the way what octane of gas should I use , i have 89 octane in my gas tank right now,Any help will be much appreciated...Thanks
new here..
