rucaradio
Thread starter- Joined
- Aug 23, 2008
- 184
I've got a VP 131D with a 275 leg. I'm in the middle of a restore (deck/stringers/transom), and with the motor on a stand in the garage I'm going thru a few systems and fixing problems.
The biggest issue with the motor is the sea water cooling system. Every seal in the system leaked, so I've purchased new O-rings and gaskets for the entire deal (along with a thermostat kit).
The PO used Red Permatex to seal EVERYTHING. I've spent HOURS cleaning it off.
The question, should I use some sort of ATV/permatex (not the red stuff) when I put everything together, or are the o-rings good enough to stop leaks?
