jhvsmiller
- Joined
- Mar 12, 2006
- 8
I have a 72 Searay 22' Cuddy with a Mercruiser 888 ford 302 / 188 hspr. It has been a great boat but I was not careful enough last winter and the Block is cracked. Engine has about 1200 hrs but used no oil.
I have aquired a used replacement engine from a trusted source; the replacement is a 1979
302 Ford truck engine, good compression, does not burn oil, very clean oil, 70k original miles.(the low mileage truck rusted through).
I can see from the threads on this forum that their are two different firing orders and camshafts: one is used on the 302 truck engine, the other is part of the 302/188 marine setup.
My question is should I pull the camshaft from the cracked block and use the marine cam and firing order? If so will I also need to use the marine heads (351w heads)?
I would like to get away with using the truck set up but I understand the marine firing order generally is easier on the rod and main bearings. Is this really the case and if so is it significantly less stress?
I am not a hot rodder--I usually run at about 2800 rpm 3200 is really max for me--I generally am more concerned about fuel consumption than speed.
